dingbat
- Joined
- Nov 20, 2001
- 17,320
Re: Opinions on power: 150, 200 or 200 6cyl ?
Different applications have different needs.
I think you'll find that guys that boat the salt typically use their torque more so than their HP. They spend a lot of time off plane where torque is more important. If you get caught in a storm and have to slug your way through it at displacement speed it's the torque that is going to save your butt, not the HP.
If you fish places like the shoals at the mouth of the Hatteras Inlet or the rips in the mouth of the Delaware Bay it is no replacement for displacement. When you need throttle you need it now and you need lots of it in a hurry.
I don't mean to slam any oif you on this topic. It just needs clarity, and it happens to be a pet peave. Higher peak torque values mean the "ability" to make more power at low RPM, it does not change high RPM operation and it also doesn't matter if you do not hammer the throttles. If I run a 1000 lb/ft. peak torque engine at 1/2 power, I am only generating 500 lb/ft. . . . However with all other things being equal, if I have a 500 lb/ft engine in one boat and a 1000 lb/ft peak torque engine in another and the 500 just can't quite plane, then the 1000 lb/ft one definitely would . . .
