Opions on remanufactured carburetors
nateo
There's an outfit on ebay called carburetor exchange out of cali that has a lot of listings for re-manufactured carbs. Couple of questions about this. Does it take some serious skill to rebuild one of these suckers (I've watched some videos on it but I have some doubts)? The listings says that everything will be preadjusted but will there be additional adjustments specific to my bout?
-Nate
achris
More fish than mountain goat
Re: Opions on remanufactured carburetors
Depends on the Carb. Webers and Edelbrocks are so simple you could do them in your sleep. Q-jets, not so much... They take a lot of very delicate work. Still doable, but time consuming. Whenever you're working on any carb, you need to be meticulous and have an eye for detail...
ANY carb you put on any engine will require final adjustment of mixtures and idle speed, and maybe choke setting. The other things, choke plate pull down, float level and drop, accelerator pump stroke should all be set on assembly.
HTH.
Chris........
lamphega
I have a 1975 Mercruiser inline 6 that I was having problems with...carb. problems. Tried a rebuild myself without luck. Then use Flying Fish Marine carburetors and traded my old for a rebuilt one. No more problems. They flow bench test their carbs and all I had to do was bolt on and go! Very happy with service and response. Two seasons past and still going strong.
Maclin
If a carb just needs to be refreshed then just a kit works ok. If the carb is old and the throttle plate bushings are worn then a reman carb is what is needed.
kbsunlovers
I've been burned by another west coast vendor - not the one mentioned by the OP or any of the responses so far. Was the wrong Q-jet housing, jetting was waaaayyy too rich. Didn't even ship with the correct base gasket, so had significant vacuum leaks.
I was suspicious when the application chart covered a large variety of years and models - but I didn't listen to that little voice.
gm280
Some years ago now I bought a very great book about carburetors. It was printed for Holly carbs and after reading it from cover to cover and reading it again, I was amazed just how simple carbs serious are. They explain ever type circuit in most ever type carburetor and how they came about the changes over the years to satisfy the demands of any engine. Once you understand how any carburetor works, it is pretty easy to rebuild or refurbish most any carb. Of course there are good reasons for swap out type carb shops too... JMHO!
airdvr1227
I had an issue with a reman carb. Purchased it in February...was pretty cold until nearly June. Installed it and it wouldn't idle. Didn't matter what I did. Had my mechanic look at it and he said the idle circuit was eff'd up. Because it was almost 3 months after I bought it they didn't want to refund my money. Took a bit of doing but I was able to get a refund less a re-stocking charge.
JustJason
The problem with rebuilt carbs is most places will not test for leaking throttle shafts. As it's very hard to do unless the carb is on a running engine.
Bamaman1
Most carbs used on I/O's will have a cast iron base and they're rebuildable time and time again. And any good auto mechanic should be able to clean and rebuild a carb for a boat. Most boat carbs. are actually much simpler than car/truck carbs--back when they ran them.
You just have to get a carb. kit before the rebuild can be completed.
I had a Mercruiser 470 (1980 model), and the carb. couldn't be rebuilt. It was actually the same Rochester carb. that a 1967 Chevy 307 used off an old Impala. That tells you how Mercury was when it came to high tech in 1980--13 years behind the times. I just used another auto carb and put the parts together.
JustJason
As somebody that rebuilds 100+ carbs a year. (I do at least 1 carb job a week, be it a single IO carb, or a 4 pack from an OB) I would say that the rule of thumb is any carb over 10 years old has a 50/50 chance of a rebuild being successful. And the older a carb gets, the worse those odds get.
Throttle shafts are moving parts, and moving parts are considered wear and tear. Depending on the actual specific carb your doing. Some have seals or bushings on the throttle shafts, but most do not, but once the throttle shaft wears into the carb bore and there is an air leak at the throttle shaft, the carb body is no good. And carb replacement is mandatory.
Carbs are also just a soft cast pot metal with a glazing on them. The glazing eventually fails. Carbs get porous internally, and will develop fuel or air leaks. This is basically just a matter of time with any carb. Air leaks cause funny things, and hard to diagnose problems. I once rebuilt a carb, left it on the bench, and filled the float bowls with fuel to see if it leaked, and sat there and watched fuel defy gravity and leak right up and out of the top of the housing of it because there were micro cracks under the glazing.
Some are so bad internally that no amount of time in the heated ultrasonic machine does any good.
Lastly... Mercarbs suck, Rochesters are good but more complicated than they need to be, Edelbrocks are the best "value" on the market, Weber is overpriced italian bullcrap. These are of course all my personal opinions, but I can tell you about Solex and Stromberg carbs if you needed to know something. And my last dog was named Holley =)
I do a loooooot of carbs. Remaned carbs can be a crapshoot. If you have local rebuilders, I would stick with them, as they are more likely to help you out if you have a bigger problem.
achris
Wrong. Only Rochester 2-bbl use cast iron bases. Most carbs on I/Os are either Weber/Carter/Edelbrock or Rochester Quadrajet, which are solid cast Ali...
Marine carbs are slightly different to auto carbs, internally vented float chambers, no vacuum advance port, a port in the top of the throttle barrel for the fuel pump overflow line. They are not simpler, but they are different, and a re-builder needs to know what those differences are and why...
No, it wasn't. Read my sentence above. It may have looked the same to the untrained eye, but it was different...
Using an auto carb on a marine engine is a VERY bad idea. It's the perfect recipe for a very loud noise... :boom:
Chris.....
