Hey everyone, I was going to run the engine one last time before putting it away tonight. I went to fire it up, turned over just fine, but as soon as I turned the key past the choke (one beep), and turned the engine over, it started to beep intermittently as long as the engine was running.
The engine fired up okay and idled fine. I didn't notice the idle too high or too low, and the engine didn't chug or sputter or anything like that. I never saw any water coming out of the pee hole, but it usually takes a few minutes before it starts cycling through and since it was beeping, I didn't run the engine that long before turning it off.
I let the engine sit for a few minutes and then tried it again, same thing. I can't seem to find anywhere on the internet what this beeping refers to? It has been freezing here overnight, could it be anything to do with the weather? I've got oil in the reservoir and I primed the bulb like always.
Any thoughts, thanks.
