a70eliminator
- Joined
- Sep 9, 2007
- 3,762
Helping my friend with a 90 hp optimax, it starts right up on muffs but we see no tell tale, motor idles for 10 mins and maybe just get a little trickle from tell tale, lots of water at the prop outlet. Pull lower and inspect impeller, looks good, made sure lock key is properly inserted and spin impeller clockwise into housing and reassembled, still no water at tell tale, looks like the hose from tell tale comes from bottom of starbird head and is not plugged. What am I missing here, the waterpump outlet appears to fit nice into rubber boot inside the upper housing, I even tried to stick the garden hose into that and blast water directly into the watertube but still nothing from tell tale, I can hold my hand on the engine block and heads and only feel warm not overheating, does water only spit from tell tale when engine reaches temp? maybe 10-15 mins at idle not enough to get hot?
