optimist pram restoration.
kayakn
Optimist Pram Restoration
so here are some pictures of the optimist pram that i got for free. It was sanded down many years ago before i got it but when i got it it needed sanded down to bare wood because the original varnish was peeling.
Here are some before pictures:
http://i349.photobucket.com/albums/q...n/IMG_2680.jpg
http://i349.photobucket.com/albums/q...n/IMG_2681.jpg
http://i349.photobucket.com/albums/q...n/IMG_2683.jpg
http://i349.photobucket.com/albums/q...n/IMG_2684.jpg
http://i349.photobucket.com/albums/q...n/IMG_2685.jpg
you can see that the outside was varnished also, but i decided to paint it because i did not think the varnish would turn out good. i had to use a belt sander and sand all of the varnish down to bare wood. i chose to dig out the rotten wood from the back and putty it because it would be covered up by another piece of wood. I also had to putty the screw holes on the bottom and around the trim,cut a hole in the seat and add a brace so i could add a mast and sail, i had to cut a new centerboard because it didn't come with one. here are some after pictures:
http://i349.photobucket.com/albums/q...n/IMG_2743.jpg
http://i349.photobucket.com/albums/q...n/IMG_2744.jpg
http://i349.photobucket.com/albums/q...n/IMG_2745.jpg
http://i349.photobucket.com/albums/q...n/IMG_2746.jpg
http://i349.photobucket.com/albums/q...n/IMG_2748.jpg
http://i349.photobucket.com/albums/q...n/IMG_2749.jpg
http://i349.photobucket.com/albums/q...n/IMG_2750.jpg
i used bristol finish for the inside and HMG primer and HMG paint on the outside.
the boat is almost done, all that is left is to put a board on the back so it is thick enough to mount my motor on and I need to put a cap rail over it. also i need to finish mounting the sail hardware and finish varnishing the rudder,centerboard,and rails that go on the bottom to protect it.
