options for boat cover supports
charliedaubitz1
My cover fits good but it continually catches water when it's a heavy rain. it's a black cover the the supports that hold the cover up front and back were pvc and under the black cover it gets so hot the pvc bends. I found a good replacement for those. 48"x84" for the front and 48"x96" for the rear. they inflate with a cordless vacuum.81qbVLuvqXL._AC_SX679_.jpg
StewartL
Those inflatable supports are a great fix. They'll hold the cover up to shed water and won't heat up and bend like PVC. Just make sure the cover is tight so the supports stay upright in wind. Good solution.
crazy charlie
As your pic shows, your cover either does not fit correctly or you do not have it strapped tight enough.Inflatable is a good idea .You can use a host of things as support .I have used plastic easy assemble saw horse.Charlie
mike_i
I use several pieces of PVC to hold my cover up and never had an issue with the heat affecting the PVC, my cover is dark brown. Where do you live and how hot does it get?
charliedaubitz1
St Pete, Fl. it only gets around 95 or so but the plastic bent from the heat, I'll post pictures the next time I go to the boat.
charliedaubitz1
Thanks, it's a universal cover that came with the boat. I try to work with what I have. There's no stretch in my cover.
airshot
Add extra grommets in the cover so tied owns or bungee cords can be added to help keep cover taught. Back in my younger days when canvass covers were popular, we used inner tubes from cars, trucks etc to lift our covers. Back in the day, if they got a hole, they were tossed. We would scour tire stores for inner tubes, bring them home and patch them up.. Those bags look like a great idea and price seems reasonable, if you compare today's price on an inner tube !
charliedaubitz1
St Pete, Fl. it only gets around 95 or so but the plastic bent from the heat under the black cover. I put a broom stick in the longer pole to strighten it. I'll post pictures the next time I go to the boat.
