Ordering epoxy and worried about amine blushing?
bzajdek
I have never used epoxy and I am worried about the blushing that might happen. Can anyone explain this process and how to overcome it? I am repairing a transom and installing two bench seats with other minor scrapes and such.
Bob_VT
Re: Ordering epoxy and worried about amine blushing?
There is no simple answer.
Google epoxy blushing and be prepared to do some reading.
Ayuh,...
Short story is,...
Prep the work area,+ start laying up your work,...
If the task can't be completed in 12/ 24hrs,... Or Less...
It'll blush,+ you'll need to Sand again...
Anytime work is left for a time,...
Sanding will be necessary before you restart the lay-up...
Mark42
Depending on how quickly the cure rate was, and how humid it was, the blush was non-existant to bad (my hardtop project). The good news is that it just washes off with a soft scrub brush and water w/dish detergent. Follow the manufacturers instructions. Often if you are re-coating within a few hours, no sanding is needed to get a chemical bond.
I used a bucket with soapy water, scrubbed the area clean, and washed clean with the garden hose. I had read various accounts about how hard it was to remove, but I found it did not apply to my project. I used epoxy from fiberglasssite.com.
But again, the most important thing is to follow the manufacturers instructions/directions.
