Orlando Clipper repair
Tim Frank
I have a 15 ft Orlando Clipper runabout, vintage c.1959/60.
Remarkable hull shape, quite rounded, and when planing has virtually no wake.
Currently powered by Nissan 40 HP after 30 years with a Johnson 55. Performance is about the same. Full speed ~ 40 MPH.
The transom is failing, it appears the layer between inner and outer aluminum skins is shot.
I am pretty good with tools and am prepared to have a shot at this repair.
Has anyone had any experience with this type of repair on Orlando Clippers?
My approace would be to take off the inner skin and remove the remnants of whatever was there....appears to be some sort of wood core, 1 - 1/2 " thick. I would laminate a new core from 3/4" marine plywood, coat it with epoxy resin, and refit.
I plan on adding a pair of diagonal braces from the upper motor securing bolts to the gunwales.
Seems reasonably straightforward.
Any comments, advice, or sources of information on these boats and their Manufacturer would be appreciated.
ID plate on the front says only "Orlando Clipper" , Orlando Boat Company a division of Southern Lighting Corp. and max HP of 50 HP.
Rgds,
Tim Frank
tashasdaddy
Re: Orlando Clipper repair
they are a great old boat. you are 100% on the right track.
coolguy147
yes, i have an orlando clipper:eek:
amazing boat! mine is only rated to 45hp =( but i have a stubborn ole 1961 merc500 on it:p
Tim Frank
Transom is all done and went really well.
I posted progress reports and pics.
The diagonal braces that someone had suggested to me were a great idea.
