Out Drive Identification Help
DFord143
Boat is a 1970 Gibson 36' with a Mercruiser 225HP 302 installed. Clearly the out drive is toasted thanks to electrolysis that got it so bad there are holes and pieces missing. I need help identifying exactly what the out drive is so I can find a replacement. Thanks all in advance!
Ayuh,.... It's a TR/ TRS drive,.... Been outa production for many years,....
I would pull the ford motor and all the drive components, then drop in a 6.2/bravo package
DFord143
Is it possible to find a TR/TRS drive on eBay or anything anymore?
6.2 Bravo package.... motor/drive/everything? Any idea if the transom holes are the same or would I need to redo the transom as well? Not that it matters much, just wanting to know what can of worms I'm opening up.
transom key is same, later drives have two extra holes that you need to drill.
it may be possible to find and old TR/TRS drive, then rebuild it, however it may be cheaper to go with something built 40 years newer. it will definitely be faster to find a late-model wrecked boat
DFord143
Funny, I saw that TRS on there and barfed at the price. Gotta pay to play though, I get that. That is just the outdrive though and ideally I'd like to get the gimbal ring and housing and the bell housing, basically everything outside the transom.
you should price a rebuilt Volvo Penta 290DP
Nope,.... Different hole,.... The TR/ TRS is a bigger hole, much like the older Volvo transom holes,.....
Smaller than an OMC Stringer hole, but bigger than the now industry standard,....
learned something today..... I thought the TRS used the same hole as the MC1.... guess not.
Ayuh,.... It's almost exactly the same as the old Volvo large cut-out,....
Matter of fact, there's an adapter plate out there for closin' in the Volvo/ TR hole to the standard Merc cut-out, for 'bout a grand,..
I've seen Bob use that adapter for both,...
DFord143
There was a question raised amongst friend that perhaps I could use an alpha 1 gen 1. Any truth to that?
based on what Bondo is saying.....no
the choices are fix the transom and move to either an Alpha or Bravo or stay with the TRS drive or get the adapter
that adapter plate that Bondo references in post #13 is required if it is the one for adapting a Volvo AQ / BMW hole to an Alpha/Bravo. the Mercruiser part number is 827691a1 and it is between $600 and $1100 depending on where you get it. Mercruiser is cheapest
here are a few links
http://www.marinedepo.com/product-details.php?id=178
http://www.crowleymarine.com/parts/264393.cfm
https://www.marineengine.com/parts/...s/1994-up/transom-adaptor-sterndrive-827691a1
http://www.mercruiserparts.com/827691a1-template-kit-tran
DFord143
One of the guys that works for/with iBoats thought he had an outdrive. Turns out, nope. This outdrive is three feet tall from Skeg to lifting ring.
Looking more and more like a repower is the answer. Where are good places to source from? Just buy a boat with what I need off craigslist or something and strip it?
Ayuh,.... That's the Best, Wisest, generally Cheapest way to do it,....
