out drive oil
edthearcher
I have a 1986 350 merccruiser with a alpha 1 out drive how many ounces of lower unit oil does it take any suggestions on what kind i should put in it
Re: out drive oil
Ayuh,..... Ya gotta buy 2 quarts, as 1 won't do it,... you'll have some left,....
Ya can't go wrong with the Merc. Hi-performance gear oil,...
It's a dyed Syn-oil of 75W-90,....
I use Mobil 1, 75W-90,.... just no dye, light amber color,...
edthearcher
Re: out drive oil
thanks for the help will get some today, ordered a repair manual also todat\y
Re: out drive oil
Ayuh,.... There's links to the Factory Manuals up in the Adults Only section at the top of this forum,...
oldjeep
Re: out drive oil
Make sure you also ordered the pump that you need to fill the drive from the bottom unless you already had it.
