stronga
- Joined
- Jun 20, 2007
- 18
I have a 1986 140 I/O Mercruiser. I took the lower end/gear case of the out drive off to replace the impeller. I didn't put the shifter in forward when I put it together. When I tested it the prop would not turn. I took it apart and now it will not go back together. When I slide the lower end/gear case on it seems like the drive shaft is hitting something keeping the gear case an half an inch from mating to the drive shaft housing. What do you think I did to screw things up? The splines on the shaft and the drive gear look ok. Suggestions?
I happy to find this form.
