rolmops
- Joined
- Feb 24, 2002
- 5,534
I started a similar thread about a year ago and I cannot find it back so here is a short history. The bracket is on a 19 foot Islander and has a 9.9 2 stroke Johnson. The problem is the proximity of the cables to the stern when the bracket is raised. They touch the stern and bend in a bad way. I was advised by a board member to use longer cables with a full loop with large radius. That did not solve the problem. Now I am going to try to put a 4 or 5 inch wide aluminum aluminum I-beam between the stern and the bracket in order to move the bracket farther away from the stern thereby creating enough of a distance for the cables to loop around instead of bend. Did anybody try this? If so, is there the need to lower the entire bracket farther down because wave action may cause the 9.9 prop to come out of the water when the stern goes over the top of a wave? Or is that negligible? How much harder will it be to get up on plane because the weight is now farther back? I do have trim tabs.
Thanks for any shared experience help and opinions, Cornelis
