johnmark
- Joined
- Jun 8, 2009
- 104
I traded for a 1961 15 ft glasspar with a 1976 35 hp evinrude the prop is chipped on all the blades really bad shape. I found water in the lower unit,installed new o ring on the bushing,replaced the retainer bolts (they would'nt tighten down) took it to the water and putted around alittle did'nt run at WOT much with the bad prop. But I did try a open her up alittle and when the rpm's went up the motor bucked against the transom like it been bucked by horse. got back and just to be safe pulled the lower unit again and checked the gears ,dog and everything looked really good . is the prop reaching a point when spinning that it gives way and the motor is dropping against the transom ? thanks a ton, John
