Re: outboard dynomometer
I have used both these dynos and can tell you they each do well until you get to the 175 and up range. At that point the nervousness of using them at WOT and having a motor freewheel is always in the back of your mind.Water dynos require a strong volume of water with good pressure, and may require some plumbing upgrades to your shop,or access to a hydrant.Oil dynos are bulky and clumsy to use and always in the way when they are not in use.Though LAND AND SEA has the ability to load their dyno at the helm ,it is wise to use two operators with either dyno.Did I answer any questions for you,or just confuse you further?
