Re: Outboard, inboard/outboard, and the third?
The only practical use for an inboard bow rider is if you need a competition ski or wakeboard boat.<br /><br />A few of the common brands are Mastercraft, Malibu, Moomba. They are second-to-none for watersports, but extremely limited for any other type of use. Most start at $40K US and go up (a LOT) from there.<br /><br />Pros of this type of boat: PERFECT for pulling skiiers and wakeboards due to various methods of wake size control, prop is safely under the boat so it can't chop up people in the water, zero to 30 mph accelleration is incredible, high horsepower.<br /><br />Cons: Expensive, no ability to go in shallow water, no tilt/trim capabilities, more difficult to launch, more difficult to dock/steer/maneuver in tight areas that require reverse (rudder steering is MUCH different from prop steering), flat bottom doesn't handle well or as comfortable in choppy water as most I/O or ouboard bowriders, limited and inconvenient seating layout due to engine box dead-center. Lower top end speed, poor cruising ability, poor fuel economy.
