FairfaxFisher
Thread starter- Joined
- Apr 28, 2021
- 3
I purchased a 2005 Tracker PT175 a couple weeks ago with what I believe is a 2003 50HP Mercury outboard. Everything has been serviced and the motor starts 1st-2nd crank. The motor runs slightly rough at idle, I haven't adjusted it at all because the tachometer doesn't work. Regardless, the motor shoots good water, leading me to believe it's not the water pump and/or impeller. Where the concern comes in for me is that when hooked up to my garden hose muffs, the water being ejected is for the most part cold, with moments of hot water coming out. (hot meaning not scalding but still uncomfortable), while the side of the engine block remains warm/hot after a couple of minutes of idling. (I can put my hand on the block for however long I need without feeling any intense burn) My question is why would cold water be pumped out if the block is hot, and why would it not be consistent temp? Is some water not reaching the cylinders to cool them? The last thing is when the motor is turned off or it sputters out, warm water starts coming out instead of cold water for the last few seconds, until the last of it has drained. Looking any input helpful, hoping its something I'm overthinking and not a serious issue, the boat doesn't have a temp gauge.
