Outboard Position
jswobs
I own a 2002 1900 pro v ifs with a 200 opti xl. Prop is a laser II 21P. Motor is positioned as far down as possible. I need advice on if I can raise it up for better performance
welcome aboard.
where is the anti-cavitation plate with respect to the keel of the boat?
all sorts of information in the stickies on motor height, etc.
WesNewell
Look at the AV plate while running wot on calm waters. It should be 0 to 1" above the water line. If it's below the water line, it's mounted too low for max performance.
ahicks
Like everything else it seems like, engine height is a compromise. Raising it so high that the AV plate is above the water line may work magic on your top end, but if you can't get a skier up, or pull a tube without venting the prop, that top end speed may be worthless.
My advice would be to try it - but make sure you use it for a bit to make sure you don't run into anything like above. A simple prop change can make a difference here as well. One prop may work fine with the engine mounted high, the next not so much....
