Yesterday, my 6hp Nissan 4-stroke outboard went underwater for about a minute. I don't know the year of the outboard, i would guess 2004. I pulled it out, drained the carburetor, took it off and flushed it with fresh gas. Then took off all the lines and emptied them. Then removed the spark plug and cranked the motor about 30 times until it was dry. Then sprayed everything with wd-40. I checked the oil and it looked fine. I ran it for about 5 minutes. Today in the morning i went to run it more and checked the oil and saw it was milky coffee colored. I drained the oil and put in fresh oil and ran it for about a minute. I checked again and it was coffee colored again. I repeated the process again and saw it was coffee colored again. It seems to have gotten a little better each time but im not 100% sure. I haven't replaced the oil filter because i don't know where it is. What should i do?
Here's pictures of the oil the first time I drained it.
