Outboard up or down when traveling
seakingbob
Can anyone tell me how they have there outboard motor when traveling.Do you tilt it up or do you keep it down on long trips.I would think that when it's down there is less pressure on the transom.Let me know what you guys think
Re: Outboard up or down when traveling
Ayuh,...
I doubt you'd have the necessary Ground Clearance with it Down...
nlain
Even if you had ground clearance you should go watch people pulling into service stations, c stores, parking lots that have a dip as you enter, I have watched several skegs get the end ground off that way. So up.
tashasdaddy
that is the purpose of a transom saver, get the lower unit up so you do not damage it. tilted.
Navy Jr.
I agree with TD. Tilt it up a bit so the center of gravity is a little more towards the front and less towards the transom. Don't rely on the motor's locking lever; it's not meant for long-term use and might bust on a real good bump or jolt. Get a good transom saver. Then no worries.
jay_merrill
I prefer down, and have had a couple of boats that I could do that with, but in most cases you have to tilt the motor. This is true for all the reasons previously stated.
The boats that I trailered with motors down both involved 20" transoms, one of which was cut down to about 18", with twin engine installations that had 15" shaft lengths. Because the boats were V type hulls this setup worked fine in the water and offered an advantage in terms of draft, something that can be very useful where I live. It also allowed trailering with the engines down, without problems - I never once hit pavement with them, even on curbs, etc.
fishrdan
I'm with TD on this one too, tilted outboard using a transom-saver. Before I bought a transom saver I watched my outboard while traveling down the freeway, it was all flying over the place every time I hit a bump. :eek:
salmonee
Can you add the transom saver to most boats?
FLWakeRider
I dont have a conventional transom saver, I have a trim lock, but I am pretty sure that most attach the trailer.
kenmyfam
Transom saver and up for me.
capt sam
I've towed a buttload of boats, if I have a jackplate I usually leave the motor down, if not I put it up and use the motor locks, never, ever had them not work, never seen anyone use transom savers here.
rrhodes
Down but one is a pontoon and the other is a SeaCat. Lot's of ground clearance on both rigs.
Fl_Richard
Just to mix things up a bit...
I travel with mine partially tilted. (150 HP Looper) I tilt them up until they come off the trim piston. then slightly back down until they just make contact with the piston. I figgure that the main cylinder and the two pistons give the most support. I dont like the engine tilt lock because the engines seem tilted too much causing a see saw motion on the transom instead of up and down motion.
No one uses transom savers here either. (SW Fla)
Sooo who's right?
triumphrick
One boat has a transom saver. On the Yamaha 150 I cinch it down against a piece of 2x4 cut to fit the width of the motor bracket. Cinched down it has a good enough angle to prevent scrapes and damage to the skeg.
Fl_Richard
Key West isnt SW Florida!
You live in the Conch Republic :)
Moody Blue
No choice with my current setup. Only have 4" clearance, so UP with a transom saver.
Previous boat had the clearance but used a transom saver anyway. How can you go wrong with a device called a Transom Saver :D
Merc25XD
UP and with a transom saver....always.........
boat1010
I am thinking that if some of ya followed a boat that just put it up with the motor lock would be surprised. They really bounce around a lot. I have an I/O but use the piston lockers just In case I use a hydraulic line. I would wear off about a foot of my stern drive.
