Re: Outboard vs I/O
One big disadvantage of a I/O is weight, if you do a lot of boating in lakes with shallow water the draft on a I/O is greater then the same boat with a outboard. This also could be a determining factor depending on the tow vehicle used if you plan to trailer the boat.
