SigSaurP229
Thread starter- Joined
- Oct 1, 2008
- 2,123
HELP!!!!! Can't take it anymore going to sink the this boat.
I bought a 1982 Mercury 50 hp in March and put it on my boat. I changed the lower unit oil verified the water pump was working. I bought a new fuel line, gas tank and battery. The motor runs great idles low and doesn't seem to have the power I think it should but runs out well. I run the boat about three times and the same thing each time. Fast Forward to the end of April I go to the ramp launch and the boat will not start. So I load up a spray bottle with premix spray gas in the carbs it starts and runs off of that gas and dies. So I am thinking carb rebuild.
I am looking inside of the motor and I see that the fuel line running to the carbs is rotten so I change it, figure I am this far into it I go ahead and clean the carbs, and rebuild the fuel pumps.
Now I am in the same position as before, primer bulb never fully hardens, gas goes into the carb bowls. engine will only start by spraying premix directly into the carb then it will run off of that premix then die.
Occasionally by adjusting the idle and lean rich on the carb I can get it to run but as soon as I shut it off I can not restart it without spraying premix directly into the carb and then it usually just dies if I do restart it.
HELP!!!! Parts are a pain to get ahold of, and I am supposed to take it camping this weekend. I just don't know what to do
