tractoman
Thread starter- Joined
- Jul 16, 2009
- 370
I periodically pull the lower drain/fill plug on my Alpha 1 gen II lower unit and drain a little lube to check the condition of the gear lube. My plug has an O ring on it and not a standard gasket. Should I be changing the O ring each time I pull the plug? I don't want to create a potential water intrusion situation. The lube never leaks out but I don't want any water to get in.
