outdrive gasket question and oil fill
oldfordcrap
hi i have a 42ft excalibur offshore i had to remove one of the outdrives for some work it is a trs drive i bought the gasket kit to re install it and was wondering do i put the gaskets on dry or add grease to them or gasket sealant ect. thanks also can the drives be filled through the resevwar on the inside of the transom or must it be pumped through the bottom hole on the outdrive
Don S
Re: outdrive gasket question and oil fill
Gasket goes on dry.
Here is the filling procedure.
attachment.php
attachment.php
oldfordcrap
thank you very much photos and info are great!!!
