outdrive gear oil.
betayv
hello here 1987 350 searay alpha one outdrive I just have the boat and I drain the outdrive oil, looks black, is that a good thing?.
achris
More fish than mountain goat
Black usually indicates burnt. Burnt oil is usually a sign that the propeller is too big (too high pitch) and overloading the engine and drive... What revs are you making at WOT?
Also, when refilling the drive, use Mercury/Quicksilver 'High performance gear lube'
Chris......
betayv
hi achris I just bought this boat the last time was registered was 2009, the propeller that came with the boat I wont be using it, I will get another propeller.
