HI ALL,<br /> WHILE COMING INTO THE DOCK AT THE END OF LAST YEARS SEASON, ENGINE LOCKED UP AT DOCK WHILE PUTTING ON TRAILER. COULDN'T TURN ENGINE OVER, PULLED TOP PLATE OFF TRANSON & FOUND GEAR ASSY. HAD BROKEN, PULLED COMPLETE UNIT OFF, ENGINE STARTING FINE. SHOP THAT CHECKED UNIT OUT FOR ME FOR REPAIR SHOWED ME THAT BEARING DAMAGE ALSO CAUSED TOP CASE DAMAGE TOO. HE COULD SELL ME A TOP UNIT & REBUILD MY LOWER UNIT FOR 1500.00 (OUCH). I DID FIND A COMPLETE BOAT THAT HAS A CRACKED BLOCK. I PULLED TOP PLATE OFF STERNDRIVE & GEARS/OIL CLEAN, DRAINED A LITTLE OIL FROM LOWER UNIT, CLEAN & NO WATER. CAN PICK IT UP FOR 350. BOTH BOATS 1985 W/MINE BEING 4 CYL. 140 HP MERCURISER, OTHER IS 165 HP--I THINK GM. DEALER SAID UNIT WILL FIT, MIGHT HAVE TO CHANGE PROP DUE TO DIFFERENT RATIO. THEY SAID & IN WRITING, WOULD CHECK THIS UNIT OUT, REPLACE W/P PARTS, RESEAL & HE KEEPS ALL MY OLD PARTS SO HE COULD HAVE MY LOWER UNIT TO MATCH UP WITH THE TOP UNIT HE HAS. MY QUESTION IS WILL THIS ACTUALLY MATCH UP TO MY BOAT? I HATE TO PURCHASE THE OTHER BOAT & FIND OUT IT WILL NOT WORK. SELLDF WILL NOT LET ME TRY IF FIRST. I KNOW MINE IS A ALPHA I. MY TOP PLATE IS SMOOTH, THE ONE I'M LOOKING AT HAS A PERCH ON TOP FOR SUPPORTING WHILE REMOVEING UNIT. ANY HELP??
