I have what I think is a MC#1 upper unit married to an Alpha 1 Lower unit. The upper has the loop on the top #5209992. The Lower Unit has a number inside the casing in a cavity next to the shift rod #1623-8950-0 (last digit tough to read.. could be 6 or G).
The anti cavitation plates are almost squared off on the back.
Do these numbers id these units to 1 upper and alpha lower?
If this is the case, should there be a pre-load pin on the top of the drive shaft?
I appreciate any help
