outdrive kicks up in reverse
bigones
Howdy guys I just bought a new boat well to me anyways and I am having so problems with it. When I shift into reverse the outdrive kicks up. I have heard that there is a lock or some valve on it but I have no clue where it is. I believe its an alpha outdrive. Also the hose going from the carb to the engine the rubber one is way to big I think its a 5/8 would that cause a vac leak and cause it to loose power? Thanks
Haut Medoc
Re: outdrive kicks up in reverse
Post the year of your boat & engine make & size, at least.....;)
There is no vacuum advance in a marine set up.....;)
bigones
Its a 1980 20ft thompson, with a 470 mercruiser on it
180shabah
More details and include pics if you can.
We need to verify that you have a marine carb, before the explosion.
Adjuster
Your trim rams have failed is the reason for the outdrive kicking up.
bigones
Here is some pics
bigones
Is the trim rods any easy fix? I bet they are expensive
Don S
