outdrive noise cant understand
angie1015
this question is for my fathers investment. 1991 thompson just bought this winter. runs great however just noticed with the muffs on(on the trailer) the boat runs nice and quiet. as soon as i put in in gear still queit..... rev the rpms up to about 1800 in gear and all of a sudden a loud rattle in the outdrive. only happens in gear when i raise the rpm's. the oil is full. the motor was changed this winter. is there a quick fix for this. he is supposed to be splashing this boat tomorrow....
Don S
Re: outdrive noise cant understand
Did Thompson only make 1 type boat in 91?????
Besides that, it doesn't matter what type boat you have, what kind of drive is it. Make, Model, etc.
angie1015
sorry its a merc outdrive. the boat is a 21 foot cuddy cabin
Don S
Is the noise coming from the lower unit? Or the upper? Perhaps from the ujoint area?????
Can't say if it's a quick fix or not, till we know what the problem is.
Did you try raising the RPM up while in neutral?
angie1015
the noise is only there when the drive in engaged in gear
Dakota47
make sure the outdrive is in the DOWN position when running on muffs. chech the the u-joints.
Don S
The ujoints and everything in the upper gear box, and the vertical shaft in the lower all turns whenever the engine is running.
My guess is you have a chipped tooth on a gear in the lower unit.
Time to pull the lower apart and inspect the gears.
angie1015
no im wrong sorry the noise is the same in nuetral and in gear
Don S
Does the noise change if you turn the drive left or right? Trimming up or down?
If it does, that would indicate ujoints. Could also be a bad gear in the upper.
Did you pull the drain plug on the drive and check for metal on the drain plug magnet?
