Capt.T
- Joined
- Feb 1, 2003
- 27
I just drained my Alpha 1 Gen 2 outdrive and found that the oil was a little creamy colored. I had changed the oil in May with the recommended Mercruiser oil and put about 30 hours of use on the boat this past summer. Once the oil was drained, I pressure tested the outdrive at 12 PSIG for 45 minutes, soap tested all probable leak areas, and there were "no indication of leaks". Any reason why the oil was a little creamy but no leaks were found? Note; the boat was docked in Lake Michigan from May to October.
