I have a Alpha 1 Gen 2 outdrive that was dripping drive oil through the water inlet holes at the bottom. I have drained the oil and pulled the unit from the boat.
I wish I would have pressure tested it before disassembly, but I didn't.:facepalm:
I think the oil leak is either at the small o-ring seal between the upper and lower units, or the upper seal in the gearbox.
My research shows that changing the upper seal requires alot of special tools which I don't have.
Is it possible to pressure check the units seperately form one another?.... should I reassemble it and then pressure check it?..... should I have a shop replace the upper seal?....any other ideas?
Your thoughts would be appreciated.
Thanks
Thanks
