outdrive oil
lynnboy021
88 omc cobra... can I use Quicksilver High Performance Gear Lube 90w from wallyworld????
cr2k
Re: outdrive oil
Yes. although 90 seems a little thin depending on your local water temp.
Lou C
Re: outdrive oil
That's all I've been using for the past 10 years in mine and no problems.
lynnboy021
Re: outdrive oil
Well I will be using my boat on Boston ma ocean lol so idk 50 60 water temps...... so 90 is ok???
HT32BSX115
Re: outdrive oil
Howdy,
ANY 75-w90 (NON limited-slip type) synthetic oil will work fine as will any other SAE 80/90 hypoid gear oil....
(Mobil-1, VolvoPenta syn, Am$oil Marine, Merc-HP, etc etc)
Also, understand that there is no NMMA "marine" spec for gear oil (yet)
cheers,
Rick
Lou C
Re: outdrive oil
The Merc Hi Performance gear lube is one of the best out there and will be fine; like I said I have used it for 10 seasons no problems
