boater184
Thread starter- Joined
- Oct 16, 2013
- 15
I have a 25' Bayliner cuddy cruiser with an Omc 5.8 and an SEI i/o outdrive converted to it. At cruising speed the outdrive seems to throw up a fine mist right behind the boat, and with the vacume that's created in the seating area with the windshield closed, passengers in the rear get quite damp some days. On a 95 degree day it's not so bad, however on a 65 degree day it's not so welcome. This Sei outdrive, which apparently is pratically a Mercruiser the way I understand it, has a vented Omc type exaust bellows, which I suspect may be causing this fine spray, I'm just wondering if i can put on a solid exaust mercruiser type bellows in place of the vented one to see if that stops it ??
