Horigan
Thread starter- Joined
- Jun 12, 2016
- 757
I doing my first winterization on my signature boat (50FAPHUE) and once I finally removed the water drain plug on the port side of the outdrive, I found it fully corroded and blocked on the inside. I tried cleaning it out with an awl, but couldn't expose the internal water passage. It appears this drain plug hasn't been opened in years in winters in the Puget Sound area. Is it really necessary to drain from this location, verses draining with the outdrive up and down? I'm trying to decide if I should drill out the passage, or just leave it alone since it's survived up to 20 years without draining from this plug.
