daydreamer1252
Thread starter- Joined
- Aug 7, 2007
- 212
Mercruiser 120 serial 6809214 can't read the numbers on the transom.....the outdrive is from a later unit serial A303794.....I have never seen the outdrive hanging on the rear of the boat it came riding in the hull...rebuilt all major and minor assemblies on the drive system....rebuilt stringers and deck....no old mounting locations for front mount so took some time to align including having to move the engine side to side as well as up and down.....alignment was a thumb and two fingers adjustment....felt good and very minor effort to move bar......installing outdrive seemed to go as I had anticipated....heavy and clumsy....got drive shaft into gimbal and got engaged with coupler (a bit of push and a counter clockwise twist of the prop and it dropped in.........was still about 1" from home and was having no success with pushing or wiggling.....thought about all of the responses here with the O-rings and the impediment to getting the install done.....got a 2x4 and an 8 pound hammer (only a 6" stroke with one hand as other was holding the 2x4)...a few taps and was in to about 1/2" and started the nuts.....started to draw it up with a 3/8ths ratchet and was making progress.....all progress stopped at about 1/4" and tried a couple more taps and no go....after contemplating a bit decided I had to take it apart and start over.....
the out drive is having none of that....all nuts off and the outdrive is not binding on the studs.....cannot get it to budge.....stuck at 3/8"....the binding is at/around level of the drive shaft...you can wiggle the drive and the studs are not bound in the drive......
In all the reading I have done here it does not appear that there any differences in outdrive drive shafts or different gimbal bearings or couplers.....any ideas as to what can be causing the binding and what may be not allowing it to come apart? Where can I apply pressure to help move this back apart so I can fix what is wrong or what I have messed up?
I assume that the outdrive had been installed with the engine and the transom assembly before as the overheat damage in the outdrive itself matched what was found in the engine and the exhaust and cables.......
thanks for all the help, advice and chiding.....
