Outdrive won't lower
witt20
OK, there's probably a topic somewhere for this but I couldn't find it. After sitting up for a couple of years (It's not supposed to be stored up, I know) my 1989 Alpha One outdrive won't lower. The hydraulics come on, but it doesn't move. Is there a step by step procedure to go through to get this thing back in service?
Ayuh,..... Have a heavy friend jump on it, as you push the down button,.....
witt20
So it's just stuck? I was thinking that was a possibility, but wanted to make sure I wasn't missing something before breaking the muscle out.
Bt Doctur
another optio is to reverse the hyd lines at the pump and use the higher up pressure to try and lower them.Once free, reverse the lines again
tpenfield
My Bravo used to get stuck all the time . . . the 'step by step' was actually to step on it.
Now I don't put the outdrive(s) up all the way.
witt20
yup....topped off the fluid, had my nephew jump on it a couple of times, down she came. Thanks all
