Donald Colston
- Joined
- Oct 16, 2003
- 6
CCREW THANKS AGAIN. MY CABLES CHECK GOOD.<br />MY PROBLEM: THE OMC OUTDRIVE WILL NOT SHIFT INTO REVERSE OR FORWARD. I PULLED THE SIX NUTS OFF OF THE STUDS ON THE OUT DRIVE AND SLIDE IT AFT. I THEN PUT THE SHIFTER INTO REVERSE TO EXPOSE THE CABLE END BUT I CANT GET THE END OF THE CABLE OFF THE LINKAGE (?) TO REMOVE THE OUT DRIVE. ANYONE KNOW THE SECRET TO RELEASE IT SO THE OUTDRIVE WILL SEPARATE FROM THE KNUCKLE?<br />THANKS<br />HD1
