Team Lowes 48
Thread starter- Joined
- Jul 11, 2003
- 9
This motor has a rebuilt powerhead with many new parts including taking out the VRO and replacing with a conventional fuel pump. It seems as though I have check and re-adjusted 100 things on this motor and nothing seems to work. The engine smokes excessively and will not idle. If I hook up a remote fuel tank directly to the fuel tree by-passing the pump and gravity feed the carbs, the motor runs great. However, when the fuel pump is used, the motor may as well be used as a mosquito fogger. It has been like this for both the VRO and conventional pumps. The carb floats are adjusted to specs and rebuilt, a new pulse limiter fitting, reeds, prime bulb, venting checked, etc. Any thoughts on this would be much appreciated. Thanks in advance for the help.
