Re: Over Powered?
wilkin...<br />I believe what ob is trying to say is that you are playing with a fire you don't yet understand...<br /><br />IE, just as your hull is not designed for this much HP, riding lawn mowers aren't designed to be operated with 200 hp motors @ 60 mph, either...<br /><br />YES... You COULD operate EITHER the boating combination you've described, OR the afore-mentioned "fictional lawn mower" safely ... If and this is a REALLY BIG IF !!!, You are seasoned in the mechanics of boating, and have the sense and knowledge to keep it "under TOTAL control" at all times...<br /><br />The problem I see, is that you are putting a HUGE motor on a boat, supposedly so that YOU can ski behind it... This begs the question of what level of experience will your driver have with this combination,while towing you ??<br /><br />If, as you say, you are an admitted novice, I'd be willing to bet that most any driver you might have along will typically have no better experience level than yourself... which could be a FATAL combination.<br /><br />Like ob says... Why ask for advice, if you don't want any that doesn't agree with what you want to hear, or doesn't tell you that all is "Just Ducky" with this flawed line of thinking ??<br /><br />If it were MY family that was going to be on the boat, it would be powered by a motor, of proper HP ratings for the hull... But then that's just me... My choice would be to put thier safety, that of fellow boaters, and my own safety above my "need for speed"...<br /><br />Good Luck, Obiwan Jeeper
