Over revved--*Did we toast it?
asgrinne
We think we over reved a 155 evinrude commercial. Spewed blue smoke, we shut it down. Now it turns over and sputters then dies out. <br />Had about 1/4-1/2 tank of oil. <br /><br /> Had 120-130 compression as of last week so it WAS pretty strong.
beeza
Re: Over revved--*Did we toast it?
anita. recheck your compression this week ,blue smoke is too much oil being burned ,so if its not making any strange noises when turning over i would suspect your oiling system is pumping to much oil to the engine.
Dhadley
What do you consider over reving?<br /><br />Just curious.
asgrinne
Not sure tach is broken. But it sounded WAY wound. Which is why we shut it down. <br />Well of course the starter motor died. So thats in for a rebuild. <br />But we were able to rope pull it over, we got 2 different compression testers. The one read consistant 30lbs. on all six. Then the other read consistant 100-105 on all six with a rope pull only. <br />So i guess we have hope that A it over oiled and is fouled out. B it just needs to be primed.
Dhadley
You should be fine. I've had motors break a propshaft or driveshaft and the motor rev up high enough that it would not shut off with the key. Once I shafted it, the powerhead was fine.<br /><br />That reminds me, I gotta rebuild one of my starters.<br /><br />Good luck!
sho305
Makes me wonder how the new 4 strokes will hold up to overrev with all those extra parts in there.
Dhadley
They wont. Thats why the rev limiters are set like they are.<br /><br />Good thought!
