Overcharging?
Beater
Well I had a tach cable installed on my 1979 140 horse Merc. Well wonder of all wonders not only does the tach work but now the amp gauge does too! Only problem is that at anything over roughly 2000 rpm the gauge goes right over to 16. Now in a car this would mean boiling the battery. If I turn on the nav lights it will drop it a bit at lower revs but at about 2500 up it just stays topped out on the gauge. Do these things have a voltage regulator or is it just the higher the rev the higher the charge?
Clams Canino
Re: Overcharging?
No regulator. Common problem. Find a way to use the extra power or shortened battery and fishing electonics life will result. <br /><br />-W
Beater
Re: Overcharging?
Thanks Clams I figure if anyone would know it'd be you. This board is great for the quick answer!
andy6374
Re: Overcharging?
No regulator can fry your electronics?<br /><br />-andy
andy6374
Re: Overcharging?
Are there certain year and models which have a built in regulator? Mine is a 88 V6' 200HP carb. I hope mine is built in. The only two wires that leave my rectifier are the grey to control harness and red to hot side of the starting solenoid.
