FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
98 115 spl had a prob. with charging did all the tests and needed a rectifier, replaced it but only had 2 yellow wire and 1 red on the new one hooked it up and now i am charging 16 volt at wot. is this to much?
It will probably level out to around 15 volts or a little less once the battery is fully charged.
I have a digital volt meter on mine and have seen it hit 16 volts at WOT but it drops back down after it runs for a little while.
Good, bad or otherwise, 16 volts is common on an unregulated system. Actually, putting it in perspective, that's only about 1.5 volts higher than a regulated one.
I had that same issue on my '96 112 SPL. Put a 12 amp regulated regulator on it. Costs like $30 and back to 14.5v. Mine was going upwards of 18v and reeking havoc with my electronics.
Make sure your battery is good. I had the same problem and I changed the battery and now it doesn't go above 14.2V even after a 30 minute ride. I guess bad batteries will overcharge.
