I have a 1977 70hp johnson. I have installed new regulator, stator, battery and cable ends on battery side(motor side looked ok). Tach is now steady and voltage is fine up to 1500rpm, but when i throttle it higher voltage climbs up to 16 volts and stays there until i throttle down below 1000rpm.
Two questions: -what are acceptable charging voltages
- am i missing something (change cables ?)
