Overheat alarm 1991 Evinrude 90hp
tnduc
I was able to get everything installed. However, as soon as I turned the key the overheat alarm went off. What do I need to do now? It didn't go off last time I turned the key while the engine was cold.
jakedaawg
Verify that the motor is actually overheating, laser temp gun will work. Assuming its not overheating check for faults to ground in the tan wire,
ondarvr
Disconnect the tan wire and see if it stops, then check the sensor, there should only be continuity between the leads when it's hot. As in over heating
