Themanofsteel
Thread starter- Joined
- Jul 11, 2015
- 312
So I have a bit of a puzzle to solve. I recently purchased a 1998 Trophy. The Overheat alarm was not working. After doing several tests I concluded that neither the engine sensor nor the positive was reaching the alarm. The alarm speaker had a Purple and Tan/Gray Strip wire connected to it. Both wires go to the engine.
When I looked at the heat sensor on the engine, its was connected to a solid tan wire. I found the tan/gray strip wire and connected it to that instead and was able to trigger the alarm.
The purple wire was not connected to anything. In fact it was capped off with nowhere to connect it to. See Photos.
I temporary connected it to the positive on the battery and the alarm works but there is no place on the engine to connect the purple wire. It's bunched up and wrapped with a bunch of other wires.
Where should I connect it to and out of curiosity, what is the tan wire and why might have the overheat sensor been connected there?
