steve forsythe
- Joined
- Nov 7, 2001
- 245
1988 Rude 80hp...the overheat alarm went off a few times even though it had a good pee stream. The pee was the same temp as the ocean...(not really warm at all). What should i check to see if it is a bad sensor or something worse going on. Other than that it ran fine...good power etc. Just when you got it up and running, the alarm would go off. Should the pee be a cool temp? And how can it overheat if it is peeing real good?
