snake91876
- Joined
- Jun 25, 2007
- 211
i have a 1989 johnson gt150 that i just bought, removed vro and premixing , just got back running on muffs in yard and heads are real hot cant even touch them hardly. I was wondering if this is normal i test the tan overheat wire going to the thermostat in head and i ground it coming from harness and get no alarm with key switch on. what can i do to fix and tell if engine is right temp, its not peeing real hard but steady cold stream. what should i check next, thermostats, water jackets, any suggestions i pulled lower and pump is brand new but some water is in area around pump housing should this be like this.
thanks matthew
thanks matthew
