Hi, My overheat alarm is going off in the helm control. here is what I have done so far: Replaced the thermostat, and gasket, made sure the pressure relief valve was not sticking. Replaced water pump impeller. When I hook it up to the earmuffs it picks up and pumps a strong stream and never seems to get warm ( the water out of the pee tube) the heads do get hot enough that you cannot keep your hand on it for long. I am at wits end , what do i do next. The motor has very low hours and has been sitting for the past 5 years.
