overheat at high rpm suzuki dt85
jjroebuck
Hi, Well after replacing the following parts i still have the same problem... impellor, head gasket, temp sensor,.. the boat has good compression 120,125,130. cranks and run good until u power for 1/2 mile or so then it temp start to rise.. put it at idel and it will cool down.. any ideas.. thanks
jjroebuck
Re: overheat at high rpm suzuki dt85
Hey bud,,, changed the thermostat and then just removed it... same problem
deejaycee_2000
that might be your problem, you must not remove it as it is there for a reason ... the motor need the thermostat .....
cousinabe
did you replace the wear plate when you did the water pump... or just the impeller?
