Lou C
- Joined
- Nov 10, 2002
- 14,284
I've posted this many times over the years but here goes, there is NO need to pull the stat to pour AF in the engine. You just disconnect the big hose at the stat housing, put a funnel in it, and fill it till AF spurts out of the neck of the stat housing. Then fill your manifolds via the feed hoses. I also disconnect the raw water intake hose at the stat housing (Alpha & Cobra) hold it down to drain it, then hold it up and fill with AF till it comes out the water intakes of the outdrive Re-connect hoses and done. If you have a Volvo or a Bravo, you can disconnect it at the impeller housing & do the same thing, then re-connect. With those I'd also disconnect the hose from the impeller housing to the stat housing at the stat housing and fill that with AF, then re-connect.
I also coat all the hose nipples with some marine grease (Evinrude triple guard) that keeps the hoses from getting rusted on the nipples, and makes your life easier. Also coat threads of metal drain plugs with that, or gasket sealer, same reason.
