cousineddie
Thread starter- Joined
- May 4, 2008
- 11
I had my 95' 90 HP Force on the river the other day and about 5 minutes into the ride the overheat alarm went off, I shut the motor off for a minute and restarted and accelerated up to a plane and it went off so I continued my ride with a steady stream out of the pee hole which it also had when I was idling around 900 to 1000 rpm. When I brought it back to the dock it again went off after about 5 min. of idling so I pulled the boat out of the water and took the cover off and it did'nt seem hot at all, in fact I touched the heads and they we're just warm. I just recently had a new impeller and t-stat put in and have only had it in the water maybe 4 times with no problems. The only thing that I have done to the engine since the last time out was put on a Cobra Marine stabilizer. Is it possible this is some how disrupting the water flow to the water pump. I know it behind the intake. I pulled the plugs out and they all look fine no signs of a headgasket problem. Any Ideas?
